RangerJ
1989 4x4 xlt 2.9 auto. Can the valves and rocker arms be adjusted. Been told twice that they cannot. Just wondering is it yea or nay
2.9s do have a way to adjust the valves
your engine has hydraulic lifters that automatically adjust valve lash. there are no adjustments.
if your valves are making noise, its likely due to worn pushrods and rockers. cologne engines are somewhat known for this problem. the fix is to replace the pushrods and rockers.
ill admit its been a few years since ive been under the valve covers of a 2.9....but im still not sure. i dont understand why ford would use hydraulic lifters AND manual lash adjustment on one engine.
Here is the Chilton instructions for setting the valve lash after replacing the hydraulic lifters and/or push rods.
On 2.9L engines, adjust valve lash as follows:
Loosen the valve adjusting screws several turns.
Slowly tighten the adjusting screws until the rocker arm faces just touch the valve stems.
Turn the adjusting screws in another 1 1/2 turns.
Run the engine.
Any questions?![]()
