I guess it would make the most sense for me to post here.
I have a similar question.
I'm thinking that I may have a vacuum leak that is causing a lean condition when my engine is hot.
I don't know how to track down a vacuum leak. I've never done it before. I know how to find a leak when something is leaking air - just squirt some soapy water around until you find bubbles.
But how can I track down a vacuum leak?
Tracking down a vacuum leak is easier then you may think.
First grab a propane torch. Don't Light it. we want the fuel, not the flame.
Start the truck. make sure it will idle or if its stalling have someone keep it going at a steady rpm. steady rpm is important.
Take that propane torch and open the valve Don't light it. Wave the propane around the suspect vacuum lines. If you have a vacuum leak the propane gas gets sucked into the engine and burns causing the engine to rpm up some. so keep the propane away from the intake.
This also works for finding vacuum leaks in intake manifold gaskets.
the professionals ive seen usually use spray brake cleaner. if anything its more explosive. =>
the propane if it lights outside the engine will go Poof fast
(unlikely unless you have a outside ignition source like a badly hooked up wire) .
The brake cleaner leaves a residue that can continue to burn after the first whoomph!
Its about as dangerous as lighting a BBQ => you don't need large amounts of propane. If there's a leak it will get sucked in pretty quick and the engine will let you know pretty quick as well.
The alternative is to use something that will bog the engine down. Like fogging oil or something. This takes longer to find the leak and then you get left over with fogging oil in the vacuum system and over everything else, also takes a while to work out of the vacuum system.
