V8 Manual Steering conversion
Dan B.
January 2012 STOTM Winner
MTOTM Winner
Armagh, PA
I want to swap from power to manual steering on my 1985 351W 2wd Ranger. I'm now running the acc'y drive from my donor car, a 1978 LTD2. The pump is huge!! It's a twin V-belt...one belt drives the alt while the other runs the PS and water pump. I need one belt to drive the alt and water pump but the current pulley set up won't let this happen.
I want to do the conversion to clean up the engine bay, drop some weight and get back a few strangled ponies!
Is there a good donor acc'y drive that will work on the 351W? Or can you recommend a good aftermarket system that will only run the water pump and alt from the crank?
I'm also looking for the manual box if anyone has one to sell.
I used a serp drive from a 90 Bronco. I made a bracket with an idler pulley and I use an XS2E 8620 EB Motorcraft belt. You will also have to swap your water pump for a reverse rotation model if you go to a serpentine setup. Most of the 302 serp drives use a reverse rotation water pump. You may also want to check out Zoops and March for complete setups. Initially, I looksed at them, but $$$ wouldn't permit. I figured that since all I had to run was a water pump and an alternator that I could modify something to work.
Here's a pic of my serp setup
The early 70's 351W's and Cleveland's waterpump and crank pulleys are what you want (same for both) If you can't find these, I have two sets of extras available--cheap.
I have manual steering and manual brakes in my 82 s10 350, if you need any info you can post or send me a PM
...and this will drive the water pump and alt??
How much? PM me if you do not want to post on the thread.
I have a box you can have for the price of shipping
