- Jan 6, 2008
- Age
- 49
- Armagh, PA
- Automatic
I want to swap from power to manual steering on my 1985 351W 2wd Ranger. I'm now running the acc'y drive from my donor car, a 1978 LTD2. The pump is huge!! It's a twin V-belt...one belt drives the alt while the other runs the PS and water pump. I need one belt to drive the alt and water pump but the current pulley set up won't let this happen.
I want to do the conversion to clean up the engine bay, drop some weight and get back a few strangled ponies!
Is there a good donor acc'y drive that will work on the 351W? Or can you recommend a good aftermarket system that will only run the water pump and alt from the crank?
I'm also looking for the manual box if anyone has one to sell.
