mudnsnow
I have a 1989 5.0L(non-HO) in my Ranger i just want to know where the redline is. When i floor it, the transmission shift at about 5500 RPM.
ok so the redline is somewhere near 4000-4500 RPM
IS the motor from a truck?
If so
185 hp @ 3800 rpm
270 ft lbs @ 2400 rpm
I believe stock they shifted at 4800, but its been a while since i driven one
Anybody know a way to adjust my transmission, so it will shift at lower RPM.
My transmission is an AOD from a 1989 FS Bronco
you can try less TV pressure, but dont go below 5 psi at idle
no it wont kill it. i didnt say take it away. i said lower it. if hes got it maxxed out now, it wont hurt it, you just have to know what you're doing. keep the pressure on the port between 5-10 at idle and it will be just fine. i have mine set higher because i want it to shift higher. that wont hurt anything either,actually its better on it. but just dont go below the idle setting of 5 and it will last.OH, and there is no vaccuum modulator on an AOD
