TNRangerBoy
What would be the easiest and most compatible engine to put in my truck, and what would I have to do/ need parts wise?
Carburated 302.
Mounts, trans, Tcase....theres lots of info on this swap. Just do a quick search
In his case a 98-01 Explorer swap is the best option. It will be largely plug and play since it is the same engine bay, fuel lines and such will hook up, etc.
Going carb on an already fuel injected vehicle is never the easiest option.
Now if the truck already has the SOHC 4.0 then the 302 swap is pointless as the power curves of the two engines are nearly identical.
While it adds an extra dimension of work an LS swap would be better bang for the buck.
Oh its an 02. I read it as 92 this morning.
Id still say on a pre PATS injected vehicle a carb is still eaiser, but thats just an opinion.
No it's not easier. You are still going from "a few extra wires to connect" to " I know, let's rework the whole fuel system that would have just hooked right up if I'd left it EFI".
EFI and wireing is a pain in the ass. With very little benefit over a good carburator.
I know you keep saying this, but it isn't one of those incorrect statements like "it's time to go home" that eventually comes true if you say it enough times.
EFI is superior to a carb in almost every regard, reliability, power, economy, and ability to operate in extreme angles.
In fact the only situations where a carb is better are scenarios, like an EMP, where the point is likely moot due to the fact that the other electricals like the starter, alternator/regulator, and ignition coil (really anything with unshielded copper windings) would probably be fried and so it wouldn't run anyway.
Depends on the carb.
You ever run the venerable little 2150 motorcraft?
They start as fast in any weather as EFI, they are as reliable as the sun, and will handle any angle a stockish vehicle should be running on....
The one on my 2.8 was a POS of the highest order.
Thats cause it was feedback and had electronics tacked on it.
Funny how that works aint it? Electronics screw everything up thats good.
I think I have heard rumblings that the Explorer powertrain into an '02+ is not quite as plug and play as the earlier trucks though, never dealt with one to say for sure. My suggestion would be '01 Explorer though.
