Upgrading tire after a flat. 1996 2.3l 2wd.
Washington, USA
I have a 1996 2.3l 2wd ranger that got a flat tire. It has the stock 215/70r/14 tires and rims.
It's incredibly hard to find that size for some reason. Someone nearby has 235/75r/15 tires from a 2001 ford ranger. Would those fit on my ranger? I see the 2001 has the same lug pattern. But I'm worried about rubbing and offset issues. Thanks.
I've got 2011 XL 2wd, running Kenda 225/70r/15 can't complain as long as it's kept under 80mph.
I ran 235/75R15 on a stock 88 4x4. I think you'll be fine on a 96 2wd. Pretty sure it's been done before.
My first Ranger was a 2wd and came with 225/70-15 and when I needed tires I couldn’t find anything I liked until I stepped up to a 235/75-15 (spoiler, 30x9.50-15 tires are often rebadged 235/75-15). Back then I actually called Ford and enquired about the change in tire size and they said you could go up or down a size without really affecting anything. So that’s what I did and never looked back. I’ve run that size on a few of my RBVs over the years, it seems like a good size for a stock rig and seems to work well with 3.73 gears.
01 rims may not fit over the hub on a 4x4 in the 97 and older stuff, but with a 2wd that’s not an issue. They shouldn’t rub on anything either unless your suspension is shot.
I'll concur to what the others are saying. We had a later model RWD Ranger at work at one point with 225/70R15 tires on it and there seemed to be plenty of room left in the wheel well. So, your '96 should be good as well.
Do it. Post some pics. I'm betting it looks completely stock.
They'll fit fine.
I bought my 2008 Ranger with 235/75 15"
