Ugly bearing noises
projectnitemare
Solid Axle Swap
RBV's on Boost
Osceola Mills, Pa
In my 89 BII w/ a 2.9/FM146/1350, the trans is making a very nasty bearing noise in 1st, 2nd, 3rd, 5th and reverse. It does it when the clutch is out in any of those gears as well as neutral also when the clutch is depressed in those gears (except neutral). I'm assuming input shaft bearing but not too sure since I haven't ripped into it yet. I'm not too worried since I have a replacement trans but rather if I should even tear it apart to fix it for a spare. Any ideas?
Matt
