Turbo fun
nesralyrrej
Ford Technician
RBV's on Boost
ASE Certified Tech
Arvada Crawlarado
Make it fast, Make it loud.
So here I am again, but this time with more fun questions! So I want to turbo my ranger, what do I need other then the obvious? Ie manifold, turbo, inter cooler, oil lines and fittings, a way to reconnect my exhaust, a better clutch/tranny? Do I need a tune? Cheap tuners? Could I use a boost controller? Do I need better injectors and a fuel pump? Do I need to replace my mass air? Or just attach it to the turbo?
A lot of questions indeed. Before you ever put a turbo on, you need to do engine work. Forged pistons are a must, and not cheap.
Next: fuel
You will need a better fuel pump, bigger injectors, a tuner, and either a bigger MAF or conversion to a different measuring system, ie MAP or VAM. Hence the need for the tuner. The other option is find a turbo coupe LA3 or similar ecu and do some rewiring.
Next:Trans the stock trans will hold 250 hp. The stock clutch, won't.
Last, turbo and exhaust.
Find a turbo suited for the power you want to make. It is crucial that it flows the right cfm at the right boost levels. Otherwise you will have crappy top end power, or horrible turbo lag. The exhaust is easy, relatively. You can buy a down pipe, or make one. They sell them assembled or just a flange.either way, welding and custom cuts will be likely.
Lol that kit and intercooler is almost EXACTLY the same as what I bought. The header might cause you problems. The straps that connect the turbo flange to the head flange broke off, which caused the waste gate to fall off. It will work but check the welds after you run it.
You can get a bigger MAF from a newer v8. And for a tuner, I suggest a quarter horse from Moates.net
I was planning on reinforcing the welds from the get go. Lol how's the turbo hold up? What size injectors you running? What about the fuel pump? Would a maf off of a 2000 f150 5.4 work well? And with the eec iv don't the tuners always stay plugged in? Are they hard to use? I've never personally used one
I went the easy way and used thunderbird parts... bolt on and set up to work right out of the box... I'm guessing around 200hp with factory parts and dead reliable...
Stock injectors and everything?
With the turbo coupe setup, you use stock turbo coupe injectors. You still have to upgrade your fuel pump. If you do it that way your best bet is to find a diner car and do the swap using as much of the stock stuff as possible from the car.
I think I'll go aftermarket, go big or go home, so about my other questions..?
Injector size is directly related to hp. If you want to make 200hp, you will need about 35#hr injectors. The truck MAF should work just fine, they make over 200hp factory, so it will measure air correctly up to the rated hp of that vehicle. My fuel pump was a $50 pump from eBay. Search mustang 225lph pump. It will work in your ranger I believe. And yes , any tuner for these ecus has to stay in. You use a laptop with the quarter horse to tune it.
where did you get your injectors? I cant seem to find any for a ranger. and with those fuel pumps don't you install them in the stock in tank cradles? or are they the frame mounted ones?
In tank. Even if you put an inline one, you have to drop the tank ( I prefer to pull the bed off) to take the one out of the tank and put a hose in its place. Injectors are easy to find. They are Bosch style injectors. And you can find them with the square style plug like ours. Or the new round plug, then get new plugs and wire them on.
nice nice now im trying to decide what pistons im gonna buy, and what rebuild kit...
