griz700rocket
- Oct 6, 2014
I bought 2 Moog K80109 caster camber adjusters and a few washers from Ace hardware. Added 8 washers under the drivers side coil and 6 under the passenger. As expected the camber was off a few degrees so I threw the adjusters in no problem. Here's the issue. I can set camber at 0 but the best I can do for caster is -2. I took the brake calipers off and I'm measuring off the back side of the knuckle. Shouldn't this work? I should be somewhere in the +5 range........What am I missing?
