Trying to pull out the rear window
Bobburt444
So I have to get this done by either tomorrow or the day after. I'm trying to pull out the rear window, but can't really get the corners loose. Any suggestions? I've tried getting a razor blade back there to cut the seal but it won't really fit. Thanks
:icon_idea: check in the tech library...! theres a write up shouldnt take you long to do either. take the int trim off too will be easier so see whats holding you up
Oh I already got all the interior out. And the write up in the tech library doesn't help cause mine's a 96, and the window bolts in.
