truck pull right after hitting bump
studdley122
94 ranger 4x4 with daystar level kit ,pulls hard to right after hitting bump in road . front end look tight , installed new ball joint about one year ago at the same time I replaced the wheel bearing & the radious arm bushings . the truck all so has a reman steering box ( changed for leak ) some times when it pulls it maks a clunk sound . HELP !!!!!!!!!!!!!!:icon_bounceblue:
Sounds like a radius arm bushing. Make sure It didn't get melted by the cat.
Also could be balljoints.
Did you have the truck realigned after installing the coil spacers?
Thans for the info it ended up being the outter u joint
