Truck has clicking noises... have sound file
jonesy2006
kinda sounds like the egr tube leaking maybe, i dunno if the rangers have a secondary air injection but if so i might be that? just throwing something out there to ya
First one sounds like a 12 yr old watching porn for the first time....
Or Boggin looking at TrucksGetDirtys pics...
In all seriousness...
It's REALLY hard to pick up the necessary tones to identify it. Can you be any more specific. If you don't feel any vibrations in the engine/tranny, I'd also point towards exhaust....mine did something similar...and it turned out to be the exh manifold separating from the pipe. Can you describe it as well as possible? Is it RPM dependent?
Are all the spark plugs tight?
PCV valve tube not broken/cracked? Does sound change if you pull the oil cap off?
Put a leather glove on and cover/grip the egr tubing/connections while you listen.
Got any exhaust manifold bolts missing?
If its exhaust...it sounds bad enough for you to be able to feel air. Be careful and put your hand all around the exhaust, then down even by the end of the manifold. If its exhaust and that loud, you WILL feel hot air.
