RyanL
- Apr 6, 2011
- '89
Well as far as it sounded, your TFI did sound like it was on it's way out and had the classic "no start when hot" syndrome. It does sound like it's running and starting a little bit better (aside from the stalling of course). It does sound like your MAP may be busted too, but of course check the vacuum hose going to it and make sure it doesn't have a leak (or any other leaks in the system). That cable that you referenced is the kick down cable to drop the transmission into passing gear when you stomp it. Some vehicles use a vacuum hose while others use a cable. In most newer vehicles (last 1 years it's all electronic. Look around on the web and you should be able to find pictures of the whole thing. Sorry I can't be much more assistance about the cable but I don't mess with them (I only owned one automatic in my life about 20 years ago and it wasn't for very long). Also, you know about the cable tie trick to get rid of all the slack in the cables, right? Look around on here, I think that I saw a how-to on this site with pictures. I think that both the transmission and throttle cables need it.
