Trs newb, 85 ranger long bed 4x4
contech
Converted ignition to Duraspark II. This truck is old and ruogh looking but its solid. Needs lots of work! Replaced crank pulley seal but leaking. slinging oil off of the pulley. Could the pulley have wear at the seal contact area causiing it to still leak?
The seal might have been damaged when installed.If it is a groove in the harmonic balancer you can get whats called a speedy sleeve to fix it.
thanks trail b2. Ill check on sleeve.
