sebastian323
- Aug 2, 2021
- Merced, CA, USA
- 4.0 V6
Hello, I am installing a set of leveling springs (+1.5 inches) on my 1996 4x4 Ranger. I currently have managed to extract the old spring. However, I am having trouble slipping the new springs in. So far I have removed the shocks, the sway bar end links, the old coil spring, and the tie rod ball joints. Do I need a spring compressor to install the new springs, or can I remove more parts from the suspension and compress the spring with my car jack?
update: I successfully got the springs in. I used a combination of a spring compressor and having a friend step on the hub lockers to bring the control arm down. I used the spring compressor just to get the spring roughly in place, and then removed the compressors to fully install them.
