Engine trouble code 171
wgb
5+ Year Member
I have a 2wd '95 Ranger with the 4L v6 and 5 speed trans. It starts and runs fine, but it has a 171 engine code (lean on bank 1). What are some common causes for this code? I am a shade tree mechanic and can usually fix problems with my cars. But I need some help knowing where to look for this problem. No drivability problems, just don't want to burn a hole in a piston and have a real problem. All suggestions will be appreciated and followed up.
Has that O2 ever been replaced that you know of? They do have a lifespan. I think as they wear the they read leaner. What do the plugs look like on that side? It does have 2 O2 sensors right?
I'd expect a anything else (except a single clogged injector) to set a code for each side. Low fuel pressure or vacuum leak, etc.
Thanks SenorNoob. It has three sensors; one for each head and one after the CAT.
I've looked into ways to test them. I am wondering if I exchanged the ones on the headers (right to left, etc), cleared the code, and ran the truck, if it would give me a new code for bank 2? That would give me a pretty good indication that the one then on bank 2 is bad. What do you think?
Only problems I can see with that is will the wiring reach/plug in and are they stuck?
As Senor mentioned, O2 sensor removal can be a real pain. .Switching should give an indication of sensor fault. However,I realize there is a cost involved, but once they're out, you would be better off replacing them - especially if there's high mileage involved.
There are a couple of vids on the tube for code 171 (too much air and not enough fuel ) - if you haven't already checked.
I've farted around on my 94 for months now and still can't find the issue - vacuum leaks, multiple MAFs, etc - even replaced wiring from the PCM to the MAF...still can't find the issue. Good luck with it and please do let us know what you find.
Swapping the sensors, but not the wires, makes sense. Same as swapping a sparkplug to see if the issue follows the plug.
How many miles on your '95? Is it a daily driver or not?
If the truck just does local driving, does the tank with Techron or Red Line fuel system cleaner.
The stuff works upon shutdown to remove schmutz from the injector nozzles. Hey, you never know!
Sometimes a load of Top Tier mid or premium fuel and a highway run can help a lot.
Thanks for the ideas everyone. I was able to swap the sensors and clear the 171 code. Waiting for a chance to run it down the road for a while to see if I get a new code. Not as concerned with hurting the engine now that I realize the lean code means that extra fuel is being injected (may kill the CAT if I run it too long). The last trip it did use considerably more fuel than previous trips; about 1/2 tank in 70 miles (but I did have the A/C on too).
Truck has about 210,000 miles on it. Daily driver and some 100 mile trips; not my only or primary vehicle. I got it free as an abandoned vehicle. Have replaced the clutch and master cylinder, and put new tires on it. Has been very reliable, just throws the 171 code from time to time. I think I cleared it just after I got the truck (probably 2 years ago) but it has come back again and I decided to check further this time. I'll try some fuel cleaner, good idea.
Follow up and closure for my original problem. I didn't realize it has been almost a year since I started this topic. I did remove the two header O2 sensors and swapped them right to left and left to right, keeping the wires on the same side they were on. Cleared the code and have driven the truck for most of a year (Don't know how many miles - probable about 100 miles each month - so maybe 1,000 miles) and the code has not returned; truck is running fine. So maybe one of the sensors or the wire connectors was dirty, but everything seems to be happy now.
That’s great but remember that the O2 sensors are wear items- they are usually only effective for 80-100k miles.
