Transmission spins while towing with transfer case in neutral
Islandboy1220
Forum Member
South Carolina
We flat tow (on all 4 wheels) a 2019 Ranger 4x4 and recently experienced a transmission failure. It was in tow mode and transmission was in neutral as required by the owners manual. It is being worked on at the Ford service department, but they said something to me that does not make sense. They said that the transmission still gets spun while the transfer case is in neutral. I am hoping someone here can explain That statement. My experience is with mechanical shift transfer cases where neutral means both drive shafts are disconnected from the transmission. Thanks in advance.
Ask them what causes the transmission to spin in that scenario. I’m no expert on that transmission/transfer case combination. But I agree that neutral for the t-case should disconnect both output shafts from the input. That is normally what neutral means.
Welcome to the forum
If Transfer case is in Neutral then both drive shafts will be disconnected from transmission output shaft
But there is no Neutral selection on the transfer case controller, picture here: https://cdn.carbuzz.com/gallery-images/2019-ford-ranger-4wd-selector-knob-carbuzz-646598-300x200.jpg
2WD, 4high and 4low, no Neutral
Transmission in Neutral is not the same as transfer case in neutral, transmission WILL still spin if rear wheels do
There was software that could be added to older Rangers so Neutral could be added as a selection for transfer case, because there IS a Neutral in the transfer case
But not sure its available for 2019-2021 Rangers
You can remove shift motor from transfer case and manually select Neutral
EDIT:
Found it, yes you can flat tow the newer 4x4 Rangers but there is a selection/method to enable flat towing
So they did add the transfer case Neutral switch
Check out pages 211 and 212 in 2019 owners manual
Its not an overly complicated procedure, but there is a step by step method to get transfer case to shift to Neutral and you can HEAR it shift
And then display will confirm "Neutral Tow Enabled"
There is a way to put the transfer case in neutral on the 2019+ trucks, its one of those goofy procedures where you hit the brake pedal and press the start button 3 times while reciting the alphabet backwards. If you did it right it will display "neutral tow" or something on the dash.
I wonder what Tow Mode (TM) does to the t-case. If Islandboy did the procedure right and the transmission failed, then something is wrong with the truck and it will happen again.
Was it in "tow mode" or "neutral tow"? They are very very different things...
Now this is getting confusing. Sounds like they should have just stuck a manual t-case in it. It shouldn’t be that complicated to drive or tow a Ranger.
Yes, I edited my previous post
In 2019 manual pages 211 and 212 tell how to enable flat towing
Tow mode is for towing stuff with the ranger, neutral tow is for when something is towing the ranger. :dunno:
Im fairly sure the tow mode button doesn't actually do anything to the transfer case it just does what every other ford tow button does and turns off overdrive. The transfer case switch was probably just a convenient spot to put it.
This is why I always read the owners manual when I get a new vehicle, even after 47 years in the car business. I solved hundreds of customer concerns by reading their manual to them.
EDIT:
Yes, we are very much aware of the proper procedure to get the transfer case in neutral. We have the instructions laminated and in the console and we use it every time. I cannot say I have heard it, but it does give the message....and did this time as well. I just do not understand their statement about the transmission still spinning when the transfer case is in neutral. Thanks.
With all due respect, I do not think you read what I wrote. We follow the manual every time. We have the instructions laminated and in the console for easy reference. It was in neutral (tranny and transfer case, even after we towed it. That part is not the question.
Is the dealer going to test it for you? I misunderstood your post apparently. Tow mode and neutral tow are 2 different things.
Yep, we know that and did that and got the correct responses, both before and after we towed. That is not the question.
The service tech was mistaken or unfamiliar with the system
The rear drive shaft does spin the transfer case output shaft AND pump to keep it lubed and cool, but input shaft(transmission connection) would not be turning when transfer case is in Neutral
The front drive shaft would also be spinning and the chain drive, but it would also be lubed by the pump
If engine, and radio, is off, you can hear transfer case shift
It's possible there was/is a transfer case problem, and electric shift motor did move to Neutral position, the sensors for that are IN the shift motor NOT in the transfer case, so transfer case was still connected to transmission.
So you saw the confirmation on the display but mechanically it was still engaged to transmission
Upcoming TRS Events
Featured Ranger Based Vehicle
