transmission question
my question is can I use v6 tranny behind my 4 banger and will it work with ecu and will the drive shaft have to be changed my tranny went out today
different bolt pattern for the 4 nd 6 cyl engines, if you can change the bell housing (not likley) it will work. if not then you need a 4 cyl. transmission.
