- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
It doesn't need to be big... Heat transfers quite readily between two fluids rather than from a fluid to air. The problem is the fluid it needs to transfer the heat to is already at 195° so it's little wonder why these transmissions tend to run too hot and fail often.Yesterday I loaded a bunch of scrap metal in my truck. In doing so, I also removed the plastic tanks off of my F150's old radiator. This pic shows the trans cooler that goes through the radiator. It is much smaller than I had expected. Mine has the bigger radiator in it as well.
http://i867.photobucket.com/albums/ab233/shanedyches/F150/20130809_142534_zps89ae29eb.jpg
×3, an external auxiliary cooler can only be good for it.
Edit:
too slow lol
