Tranny swap/motor
Mustang351V8
Im debating on swapping a 302 into my ranger or just sticking with the 4.0 my transmission is bad ive found a AOD and a A4LD tranny for cheap but my question is will the aod bolt right on to my 4.0? And will a A4LD from a 2.3 bolt onto a 4.0? Ive heard from multiple people the A4LD is junk but if its less work id rather buy a A4LD. But if the AOD will just bolt on what would it be a better buy? http://sd.craigslist.org/pts/4719777743.html or should I just buy a 302 with tranny for 1300$ from this same guy?
aod don't fit 4.0. and a4ld from a 2.3 want fit
If i was going to spend $1300 for a motor and trans then all the extra money to make it run (exhaust,cooling, driveshafts are the first things that come to mind) I would really consider just having my A4LD rebuilt and be done with it. Back on the road quicker and less headache. I dont know what rebuilds run in your area but mine is carry-out $1200 and complete job $1800. Both include reman torque converter,new bands, clutches,steels,filter,servo pistons.,modulator valve New gaskets ,seals
and sealing rings plus updates to help on known problems with this transmission.
Good luck:icon_thumby:
The 2.3L bell housing won't fit. The bell can be swapped. You didn't specify if the truck is 2wd or 4x4. If it's a 4x4 and you want to use a 2.3 trans, GFL.
FWIW as far as I am concerned no transmission with a torque converter is worth having.
The early A4LDs did have problems(1985-1989), in 1990 when the 4.0ls came out the A4LD was changed and became a not so bad transmission, so yes they "were" bad but that changed.
As said you need to get an A4LD trans from a 4.0l, 2.3l won't work, and it should be from a '90-'93, 2.9l will work, same bolt pattern as 4.0l but '90-92('92 was last year of 2.9l).
And 2WD or 4x4 matters, that must match your vehicle.
In '93.5 A4LD got computer controlled OD so your '92 computer may not be able to control that, not sure.
Good read here on the Ranger Automatics: http://www.therangerstation.com/tech_library/AutoTrans.shtml
Read article by Gloria Roosen under A4LD section.
Important part:
"When having an A4LD rebuilt, there are a couple of things that you need to make sure of. First and foremost, do not let a shop do a soft parts fix only (clutches, servos, and bands). This will almost ensure that you will have another repair needed right after the 1-year warranty is out."
Engine swap also requires computer and wiring swap, so best thing is to find an older Explorer with V8 and body/interior damage, buy it cheap, and use it as a donor vehicle.
I might as well just buy a rebuild kit and do it myself. Or have my dad do it he has done plenty of rebuilds.
There r some trannys on ebay that offer a unlimited mile warranty. But u have to also buy a torque convertor from them
adsm08;.. without getting real technical, why don't you like automatic transmissions.:icon_confused:
Will a tranny from a 90s Explorer bolt right on? Im gonna go junkyard shopping
