Use a hair drier or heat gun, as said above, no open flame
You can test TPS with volt or ohm meter
Use a sewing pin to pierce top wire
Turn key on
Set volt meter to DC or 20vDC
Black probe on Ground, engine bolt is good
Red probe on pin
Voltage should read 4.8-5.0v, this 5v is from the computer
Move pin to center wire
Red probe on pin(Black still grounded)
Voltage should read under 1v, .7-.9 is spec, this voltage is going back to computer
Open throttle slowly while watching voltage
Voltage should steadily increase, no jumping around
With throttle wide open voltage should be above 4.6
TPS is a variable resistor, like a volume control or light dimmer.
Computer "learns" TPS minimum and maximum voltage which is why the throttle closed voltage is not specific and same for wide open throttle voltage.
TPS issues can be varied, it can cause a no start if center wire is above 4.6v all the time, and it can cause "dead spots" when accelerating, i.e. TPS voltage drops suddenly as throttle is opening, so computer reads that as you took your foot off the gas pedal.
