Test with OHM meter as well, ohms get lower as throttle opens
When throttle is closed you should read .69-.99volts, just under 1 volt
Wide open above 4.5volts
No sure what "OL" means on your meter, is it set for 20vDC, so OL means over limit, i.e. higher than 20vDC???, which is not possible in a vehicle with 12volt battery and under 15v running voltage
Computer has a 5volt power supply, it is used for several sensors, MAF and TPS both share that 5volt wire from computer
That is called a Reference voltage so doesn't have to be exactly 5volts, 4.8 to 5.2 is fine
Then computer has separate Return voltage wires from TPS and MAF, in this example.
As you open throttle, TPS variable resistor gets less and less resistance(lower OHMS) so voltage on Return wire goes up, this is same as light dimmer or volume control work.
Computer then compares the difference between Reference Voltage and Return voltage to get throttle position.
I can't see the computer being the problem because it would be a constant problem, it shouldn't occur at a specific throttle position, electrically the only change is the OHMs at TPS, should be any change in the computer end by moving TPS
The two center wire on MAF use the 5volts, see which one is 5volts, key on, and which is the Return wire, the one that not 5volts
Test the Return wire as you open TPS see if it is effected, its a separate circuit but just looking for possible computer issue.
1993 means computer is 25 years old, and these computer do have 3 blue capacitors that can leak, which can cause very odd issues, which your is
You can see them in this picture:
http://www.auto-diagnostics.info/ford_eec_iv
They are cheap and not too hard to change, under $5, if you can desolder and resolder in new ones.
So after exhausting other options pull out computer and open the top to see if Capacitors are the problem, you will see black residue under a leak capacitor
