This last one sure reads like lack of fuel, the sitting and then rough start and then stall out at higher RPMs with a no start right after.
Computer does have a "limp mode" and you can set that by unplugging the MAF sensor.
Computer then runs pre-set table for fuel mix and basic 10deg BTDC spark timing.
Barely drivable but should idle OK.
If not then computer is bad or there is a mechanical issue
