Yep, Toyota is a problem all right:
...in the last 20 years, there have been 569 recalls of Toyota vehicles. At the same time, there have been 3,498 recalls of General Motors vehicles. Yes, there have also been 2,691 Ford recalls and 2,419 Chrysler recalls...
There you have it. Toyota sucks.
What are the ratios on those though? How many were saftey, how many were compliance, how many were body, how many were just running updates? How many were revisions of previous recalls?
In the last 20 years for has had recalls for tail-gate cables, paint peeling off due to bad primer (a supplier fault), weak clock springs in the Explorer seat-backs, one for when they found a way to make the defrosters in the 09 focus work better, two for cars that were built shortly before a government update of standards that applied to those cars (which just required PCM recalibration), several updates to the cruise switch recall that included more cars that they said MAY BE BUT PROBABLY AREN'T affected by the original issue, they were just being cautious, almost every one of those updates having a separate identity. There was also the one for the door-latches freezing in cold climates, and the one for putting weather strip and latch grease on the focus doors because they were getting wet and seizing up.
Also one for updated return springs in the Expedition door handles, one for Explorer rear glass that broke WHEN THE CUSTOMER closed it TOO HARD.
One for parking brake cables that freeze up IF YOU DON'T USE THE BRAKE, one for pads that swell and wear fast in extremely wet weather... better clips on the Explorer CC cable.
One to put stronger wheels on the cop cars because a FEW failed after the cars were JUMPED.
One for the brake booster lines on the F-150 failing resulting in loss of power brakes, but retaining the ability to brake. And that's just the ones I can think of off the top of my head.
I won't get started on the Firestone Debacle except to say that Ford, Firestone, and the customers were all at fault for that. And yes, I admit the Pinto Debacle was just bad. End of story.
For may have had a lot more recalls than Toyota in the last 20 years, most of Ford's recalls were not safety related, or at least not deadly. A lot of the Ford S(aftey) recalls that I've seen were not actual severe, kill you, type safety issues. Many of the ones in the last 10 year were more update the PCM that actually change out a part.
What has Toyota had, cars taking off by themselves and killing people. Tacos breaking in half because the frame metal is missing a vital additive.
Ford's recalls cover a few specific models and years (cruise control recall being the exception), what does Toyota's recall cover? 90% of their production for the last 3 or 4 years. The Taco frame recall killed ALL 96-01 tacomas. You CANNOT find one anymore, they all have S-titles and are junk.
Toyota takes the cake in this one.
