torsion bars crank?
dancron
NJ
Thinking about cranking my bars to level my truck and put bigger tires on, anything i should know about it beforehand besides getting an alignment right away?
Just keep it within reason so that you still have some downtravel left in your suspension and you should be good (usually raising it up to 2" higher than stock won't present an issue) :icon_thumby:
thanks man, and you think i could fit 32s with just leveling it or stick to 31s?
I can get inot issues with 33's t-bars maxe and 3in BL if i wheel hard enough...........
you may ought to wait to lift it before going with too big of a tire if you offroad much, if not then just watch your backspacing and 32's should work.
Frank
dont really have anywhere to go crazy, i just play in the mud sometimes haha, and my rims have a 4inch bs
Go with 32s, I have them and it makes the truck looks 100 times better.
and you have just the stock suspension with a t-bar crank?
t-bars cranked
i have 31x10.50's on my 03 edge right now and i have plenty of room to fit 32's i cranked my t-bars 2.5" nothing else
thanks for all the help, i think im going to order 32 inch BF tires this weekend
procomp xtreme a/t no rubbing at all =)
265/75R15, its about 31.6 and no thats the stock height in the rear
if i max my t-bars & do an add-a-leaf in the rear do u think I could get 33's on? or should i just stick with 32's
