Great job
Thanks for the info, my 86 actualy has a dealer installed A/C box. I was hoping to eventualy keep the A/C as I'm not building a performance motor, at least not for now. It will be a D/D with V8 sound for the most part, just a cruiser. The crown vic motor is basicly just for moc up for now. I have a 92
F150 long block I will freshen up with minor performance mods when I'm satisfied with the fit and function. I actualy used the 150 fuel rail on the vic intake and the regulator tucks under the rear of the plennunm and the lines are at the rear as well. It's a tight fit but I'm confident it will work
Thought about using the 150 wiring and computer cause it's in much better shape than the vic but it was for a manual trans. Don't know if that would work or not with the AOD and all, so will try to patch the vic wiring.
If you havn't noticed, I'm doing this build as cheep as possible,OK I'm a tightwad. Actualy this build is like the discover card commercial
Rusty 86 ranger $0
Crown vic engine trans and wiring $0
Cost of having V8 performance in a ranger Priceless!!!
I must say I've been reading the forums a lot since I started tinkering with this build and am greatfull for the info you all provide. It will make this project
go a lot better.
