TIMING on 87 BRONCO II
groovtubin
NC
2.9 V6
Just want to attest to the setting of 10 degrees ADVANCED or ""20"" on crank wheel..+ i pulled vacuum hose off egr solenoid n plugged it..She runs n shifts FANTASTIC! Also, i dont use the AC, so i pulled the belt to UN-load engine a tad YMMV.....I DO have a slit miss at idle to work out, but shes come A LONG WAY BABY from this past December...she was a MESS...................... :) Only things id really like ta figure out is she wont move in OD static..but CAN shift manually into OD at 50mph....Im getting a "89" code for converter clutch override solenoid...gotta get off my butt n pull the pan , n have a look, connector could be off! Hope every ones wrenching is going good! MUCH thx to the technical corner n all who have helped me! :) Can NOT plug McCully racings REMOTE TFI module kit enough! What a MUST for this vehicle! :)
