jmcleek
- Jun 9, 2009
- Automatic
I recently got a 87 ranger with 2.3L with a blowed head gasket. Pulled the head , replaced head gasket and anything else that didn"t look good . I also replaced the timing belt and set the timing useing factory timing marks. When I set the distributer it will knot start unless it is at 25 degrees BTDC or more.
Cold it will run ,shift ( stick shift) and drive like normal . after warm up it gets a fluter , then stumble tell it finaly dies.
very hard to restart. After restarting it will run as fast as you want in first gear, but if you try to change gears it will die.
Warm and in nuetral, if you goose it, it will bog , make noise like diesling then die. I think the crank shaft timing mark may be off, so I am in the process of making a tool for checking that with a fouler and bolt that screws into the #1 plug hole. Does anyone know how much the bolt needs to be below the plug to work? If anyone has anyother thoughts than mine please chime in.
