Ranger Dave
Quick-lok up front and a powertrax out back. love um
8.8
D35
8.8
D35
You will never lock the front in when driving on dry pavement. A locker up front will provide much better traction when needed than a limited slip.limited slip is the way to go when you arent offroading lockers are a waste of money if your pavement pounding and they eat tires for days if you dont stay out of that throttle
well then if its not going to be locked on pavement then its basically a lmtd slip right? and why would you waste money on it when its not going to be in use, if your driving on mostly streets and freeways and not on trails then i would think a limited slip would be the better and more practical way to go and a good limited slip will provide more than enough traction for the occasional trailYou will never lock the front in when driving on dry pavement. A locker up front will provide much better traction when needed than a limited slip.
You have it all wrong if you think a locker is a limited slip if it isn't locked on pavementwell then if its not going to be locked on pavement then its basically a lmtd slip right? and why would you waste money on it when its not going to be in use, if your driving on mostly streets and freeways and not on trails then i would think a limited slip would be the better and more practical way to go and a good limited slip will provide more than enough traction for the occasional trail
Your missing my point, if your truck sees primarily pavement you would be wasting money on a locker
No I am not missing your missing point. You obviously do not realize that you can get a locker for as much if not cheaper than a limited slip unit.Your missing my point, if your truck sees primarily pavement you would be wasting money on a locker
lol....idiot, these d35 front axles are exactly the same as a 2wd when the hubs unlocked. locking the front axle ONLY hurts when you are using 4wd, this isent a jeep or a new ranger with a live front axle. the FACT you can run the d35 and unlock the hubs to completely disengage the front axle is a huge advantage of the axle. one of the bigger reasons is it is possible to obtain 2wd low range to move trailers or steep hills. become more familiar with something before you vomit out nonsense like this again.
86
Ooh I'm loving the hostility lmao but even with the rude comments I still don't see why you would install a locker in a vehicle that doenst see trail time that often regardless of being able lock and unlock hubs the locker itself is a waste of money
