bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS 25th Anniversary
Ugly Truck of Month
TRS Banner 2012-2015
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
huge fan of the 2.0 and 2.3 Ecoboost engines. the later 6 cyclone and nano as well.
if you drive 5 to 7 k miles per month using top tier oil and high efficiency filters, with low idle time and not severe towing/lugging, changing oil at 10 k or maybe more is not an issue if you change the filter at 5k. its always running ideal.
outside of that, light to normal use 5k is max. if it idles allot 3k. spark plugs should be closely monitored as well.
any thing with cam phasers, or aome sort of VT get a bypass filter if you can afford it. AND change the oil anyway......
these engines highly maintained easily make 250 plus k with mild tunes.
get all of the fittings and lines for the turbos here and there and just change it all out at 40 to 60 k. best way to go and spark plugs and throttle body cleaning if you are not catch canned.
