timstone
- Nov 1, 2009
- Automatic
Ok...I am fed up with the way this vehicle of mine is running. It's a 1991 Ranger regular cab with the 4.0. When I got it, it pretty much ran fine..it has some noise in the motor but it's nothing to get excited about.
For the last 3 or more months it has been getting increasingly worse. If I start it when it's cold I sometimes need to keep my foot on the gas for a few minutes to keep it running...although this is pretty rare. Other times it will run without having to do this but the idle seems a bit rough. It seems to idle around 500 RPM.
When the truck is like this....even if I let it warm up for a good 15 minutes before actually leaving anywhere as soon as I put it in drive and push on the pedal there is hesitation and it almost wants to die on me....sometimes it actually will die on me. The battery gauge in this state always reads lower than normal (somewhere around the N is where the needle points) but when the gas pedal is pushed down it will jump back up to the normal reading...as soon as I get to a stop sign it will drop again. It does this constantly until the truck is fully warmed up and sometimes will even do it then.
So far I've replaced the positive battery cable. The solenoid that is on the starter, the PCV valve, and all the plugs and wires. None of this has fixed the issue or even made it better.
Some people will tell me to check the battery and starter. But I have done both of these and they both tested good. I even went through the trouble to actually buy a new battery to put in the truck but even with the new battery it still had the same symptoms.
I'm lost and I can not figure this out....I don't really want to put any other money into it until I have a better idea of what could possibly be happening.
If anyone has any ideas PLEASE HALP!!!!! If you need any more information than what I have provided here...because honestly I could have left something out. Just post your question here. I'll respond ASAP.
