Off Road SHO
- May 28, 2010
- Automatic
Just picked up this 85 Ranger, 2 wheel drive 2.3 with automatic powered truck for my Son to use and we're having a problem getting it to stay running. Got an EGR code and found a defective EGR solenoid. Replaced it with used and same problem. Got temp sensor out of range codes but I don't think those would cause stalling out problems. Can't keep it running long enough to warm up, even when we rev it up off of idle.
It starts and runs fine for about 20-60 seconds then sputters out and dies. It has a full tank of gas, verified.
Fuel pressure is 25 psi while running, with the vacuum hose off the regulator (which looks new) it goes to 35 psi. That seem a little low to me. There is also what looks like a small inline filter in the high pressure line between the HP pump and the fuel rail connection. It looks to be an integral part of the hose. Is it a check valve or something.
Engine vacuum is about 16" while running.
Checked the inline cartridge fuel filter and it looks new but we're going to replace it anyway.
Did a smoke test on it and found a small crack in one of the lines near the EGR solenoid pack at the fender, fixed it, but no help.
My next guess would be something clogging the pickup screen in the tank pump pickup tube or maybe the tank pump itself.
Any ideas on where to look next? Any advice would be appreciated. Thanks
Tom
Tom
