The White Ranger...
hmm gives me some ideas
I cant say I have ever been looking for ideas on a flat bed, but when I seen his, that was probably the best looking flat bed I have ever seen.
ok another update ordered tubing bender friday... went to the junk yard and found a jeep box that should work.. decided to cut the front half's of the frame rails off to give me more up travel..
steering box is going to be moved up and I'm going to try and find a flat pitman arm... also decided that we are prob going to end up cutting out most of the core support and make one out of tubing... and the piece of tubing hanging from the strap is where the upper link is going...
definitely looks good. I cant wait to see the tubular core support.
well got some more work done on it today... cut about 16"s off the frame...
upper link is in...
Looks good rob. what is the wheel base gonna be set at?
Needs more triangulation! You need to put 60's under that thing!:thefinger:
Some pics from the other day when I showed up. For a rig with 37's and full size axles, It sits very nice and low.
