Thanks for the comments guys!
I've run into a bit of a hiccup with the steering:
Since I pushed the axle foward, my pitman arm isn't going to be nice to the tie rod. So I either have to:
- Go with a flatter pitman arm, which means I'd have to notch the frame out to keep my full swing (Not real excited about that prospect).
-Move the axle back to help with the clearance (That's not happening).
-Limit my uptravel to keep everything clear, this seems counter productive to the build.
-Run the tie rod in the stock "low" position. While that sucks, I'm not really seeing any other "easy" solutions. The DOM I'm using is 1/4" wall 1.5" OD, so It should be able to handle quite a bit of abuse in that location.
Unless I'm missing something, this is kind of a bummer.
