- Jan 27, 2010
- Canada Eh!!
- Automatic
Update time!
Last time out wheeling at the beginning of Jan 2011, I broke another rear diff ujoint. Turns out I spread the ears on the diff yoke too. Then the next bummer was finding replacement locally that wasn't 150bucks new. I finally found a used one last week for 15$, this one uses a 1310 ujoint instead of the 1330 I had on there. This means I no longer need the conversion joint I kept breaking. Waiting on another payday to buy a couple new ujoints so I can get back on the trail.
New-to-me 9" diff pinion yoke and seal.
In the mean time I decided I would redo my front brake line system too. I'll post some pics as it goes back together in the next week or so. I'm changing it from the 28" long braided lines at each front wheel to one long line at the center of the diff and short flex lines at each caliper and running the hard line across the axle housing.
Along the way this last month I came across a deal on a York air pump I couldn't pass on, 25$ for it, according to the manufacturer it puts out 13.9cfm @ 2000rpm & 270 psi!!!
I did some measuring and it has plenty of room to spare under the hood sitting on top of the A/C pump bracket, this York didn't come with a clutch or pulley ($85 for a new serpentine clutch pulley) so I'm going to try and modify the straight shaft Ford A/C clutch/pulley to fit on the York's tapered-keyed shaft. If not I'll wait and buy the new pulley. I'll finally have a reliable OBA system again!!! YAY!!!!
