TFI to EDIS Thought Experiment
Sort of. Principles are similar but the 5.0->5.8 swap is a lot closer in displacement (16% jump compared to 38% on the 2.9->4.0). You're a lot more likely to go outside of what the ECM is able to compensate for.
Ah makes sense when you put it in percentage. I was just thinking in liters. 5.0-5.8 is .8 and only .3 less then the 2.9 to 4.0 difference.
I'm definitely not saying it can't be done - given the right tweaks it's probably fine. Especially given that the 4.0 is a lower RPM engine making about 15% more peak power than the 2.9.
I'm definitely not saying it can't be done - given the right out batweaks it's probably fine. Especially given that the 4.0 is a lower RPM engine making about 15% more peak power than the 2.9.
When did the 3.0 get EDIS?
Could you use the 3.0 ECM with 4.0 sensors and such?
The fuel maps would be close then. Could be totally out in left field here though.
So, if I were to pick a year and engine of the 4.0, SOHC, 3.8, or 3.0 and strip the ignition system, which has the beat setup from the factory?
Do you actually think this needs justification? Or just trolling?
Don't you run mega squirt already.??
I have run the 2.9 with a taurus pcm before.
With your supercharger tuning a 4.0 system may work out well. It's already Framed for maf.
With your supercharger tuning a 4.0 system may work out well. It's already Fred for maf.
Yessir. Already running megasquirt.
MAF install is on the list, as well as knock sensor. Figured I'm going to have it off the road all winter, so lining up modifications to make and parts to pull
I was wondering that myself.
A 4.0 ECM should run a 2.9 shouldnt it? Then it would just be a matter of driving the oil pump and mounting stuff.
The biggest issue there is that the 2.9 has no provision for mounting a crank sensor, or trigger wheel.
I'd imagine the 4.0 ecu would need a different tune in order to compensate for the larger displacement without constantly causing a CEL. :dunno:
Not really. Worst case scenario you need to install undersized injectors, and maybe get the MAF calibrated.
Trigger wheel isn't hard.
Make a mount and sandwich an OEM piece or a aftermarket piece...
ati makes custom stuff....for custom prices...
With what house wants to do with the 2.9...its best to run as solid an ignition system as possible.
With the mega squirt you can go to individual coil firing....use that with like 5.3 truck coils or whatever....for a hot ass spark and as close to timing that is perfect as possible....
with boost...
on this thin wall head critter...
applying the effort to index the plugs to Max out flame front and that hot spark.....will greatly assist dialing in temps and knock..... resulting in a long life 240 to 270 HP 2.9
with boost...
Yup. I die, you get my future kids.
It is. We have quite a good export market too....
Marc Emery (The Prince of Pot) changed the weed game in North America (possibly the entire world) for sure. He was doing some really interesting stuff way back when.. GPS guided autonomous submersible submarines that would surface when they hit a specific GPS coordinate, using the rivers.. Shipping extremely awesome strains of seed to the US even though he knew it was against the law..
A buddy ordered some of his seeds a long time ago when you could still get them to the US, before customs started really going after Mark's shipments. It grew mind blowing weed. A real skunky sensimilla and this was long before all of this super potent modern medical grade weed.
