bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
TRS 25th Anniversary
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
No plans at all to get one. It goes closed-loop very nicely so I'm not at all concerned that it's over-fueling. That's the beauty of MAF - it measures the air mass directly and provides fueling accordingly.
to its limits. that is a problem often fought with the old school 302 and 351 stuff. you dont know until you log and measure it where it is at.
seems like you are in the sweet spot with no active codes, it is obviously not hitting a wall.
putting the larger system on the lower threshold may be ideal as better rich then lean imo....
glad to see its working well...i know supercharging a 2.9 this system might be ideal.
on the other side...puttin this system on a 300 6 might max out the airflow.
that is why i suggested to just leave the 2.9 injectors (if it was a stock unmodified 2.9 engine) before running the 4.0 injectors.
with a bad ass hci combo maxing airflow was an issue with the v8.... especially idle. and generally larger injectors or higher fuel pressure kept it going
