Tach install In a 1984 Bronco II
SgtDan94
5+ Year Member
NorCal
Title says it .. I want to install a tach in my 1984...
Is the Bronco II pre wired for a tach? What’s the easiest way to do this?
Thanks
I don't think that early model is pre-wired. You just need to hook up key-on power and ground, the wire for the dial light, which is going to be a lightblue/red, and then run a wire out to the engine compartment and hook it to the negative of the coil. That will pick up the pulses from the module and trigger the tach.
Just moved this thread to the correct forum...
