bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
TRS 25th Anniversary
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
Thats a good article, and for the most part is right, however there is some mis-info. First, The Fairmont never got the T5, dont know where they pulled that out of, second, there is a LOT of V8 cars running around with 4 banger T5's in them and they hold up just fine, Id even go out on a limb and say they arent any less strong than a V8 unit in practical use, The torque ratings are as they are from an engineering standpoint, just because the 4 cylinder has a lower ratio gearset and more force is applied to the bearings because of that. The part that everybody forgets about V8's is how smooth they run in comparison to a 4 banger or even V6. A 4 cylinder engine is much more harsh on a transmission than a V8, just for the fact that there is less overlap between combustion cycles. Either way, there is a lot of V8 cars (And built ones at that) that have had 4 cylinder T5's stuck behind them, and they live just fine. The idea that the 4 cylinder tranny is any less strong than the V8 doesnt hold water very well... Especially when there is 2.3T's out there that make more power than most SBF's and are still running through the stock T5.
Yeah, I didn't notice the Fairmont claim when I read it - good eye. As far as people using 4 cylinder trannies in a V8, I'm sure there are plenty of guys who use them and don't have issues. I won't ever use one because the pilot shaft is smaller and the input shaft is longer than a V8 trans. Those are the key differences. I'm sure you could add washers to make up the space, and might be able to find a pilot bushing to make it work. I'd rather just use a V8 unit though (unless I'm putting it in a 2.3 like the OP).
there was a time when eagle transmissions were easy to get, its why i always suggest the eagle type slave for hydro adaptation of the t5 in the 2wd trucks as a potential option.
key issues were still input shaft changes/pilots and some grinder/machine work with the ford bell, but the jeep 208 case or anny ford 208 case with an input swap bolt right in.
in reality, those older transmissions with stock v8 power with 4x4 and 33 in tires were grenades, and ime the t5 in a car over 300-330 hp is a time bomb too.
i had some fairmonts...one with a 351 that was a tire killer. i almost bought my sisters recently, and i remember a manual od but not a 5 speed....i assumed it was an srod. i cant say if the t5 ever came in them or not though...i never seen it stock, but seen it alot at woodhaven and milan. for some reason i like pintos and those fairmont things....idkw
