Swapping ignition cylinders - Advice?
acleme1
I own a 2003 Ranger 4.0 4X4.
I am wanting to swap a tilt steering column for my not-tilt column. I think everything is pretty straightforward, except I'm a little unsure of the ignition cylinder.
I want to keep the same key to my truck after switching columns. Can I just switch-out ignition cylinders?
Is it pretty easy to swap-out cylinders?
Any help is appreciated. AC.
i haven't done this on one that new, but on
older ones, you disconnect the battery,
push the silver button on the bottom,
and turn the key past start, and pull it out.
Yep, pretty much what schmoo said. Turn the key to the ON position and there is a hole with a small silver button sticking out of it on the bottom of the housing. Push that in with a small screwdriver or a pick and wiggle the cylinder while you pull out on it and it should slide right out.
