- Sep 24, 2023
- Age
- 64
- South Carolina
- 2.3 (4 Cylinder)
- Automatic
I recently purchased a totaled 2006 Ranger, base model with 2.3L Duratec and five speed auto. My plan is to just pull everything from the Ranger and plop it into a 1961 Rambler American convertible engine bay just like it came out of the Ranger -- or as close to that as I can. So I plan on using the complete wiring harness and relay center. I'll pull all the wiring from the Rambler and use the Ranger wiring for headlights and such as well. I'm not sure what I'm going to do as far as instrumentation yet. I don't think I can use the Ranger components, and I don't think I can use the Rambler cable driven speedometer either. Will probably go with an aftermarket solution. Will I have any problems with the anti-theft systems? Since this is a base model is there anything in the instrument cluster that the computer needs to see for the engine to run? I know a friend swapped engines in an early 2000s Mustang and had to swap the instrument cluster as well. Any work around for that if that is an issue? Any advice?
