Eddo Rogue
- May 18, 2020
- Burbank,CA
- 4.0 V6
- Manual
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
I swapped in an FFD Dynamics Efan kit, heres what happened:
I started the truck and let the engine warm up slightly past halfway, then adjusted the temp control to kick on the fan.
After a few mins, the temp gauge dropped, but the fan stayed on until I shut off the engine. I let the engine cool and started again.
This time the fan came on soon as turned the ignition. This was using the radiator probe. I switched to the radiator probe, and it did the same thing (off until warm, but then stays on after temp gauge drops).
I went back and cleaned the radiator probe and relocated it, which helped, it kept it the fans from kicking on right at ignition, but then wouldn't turn off again once it kicked in.
I tried messing with the adjustment screw to test the fan on/off. Sometimes it would cycle the fan, other times it did nothing.
At moment the fans kick on at ignition with engine and probe fully cold.
So far here's all I could come up with for possible problems, in order of possibility most to least:
-Defective control module (which I may have mangled despite being gentle on the adjusting screw and installation)
-defective probe(s)
-Impatient (I did all this based on my temp gauge at idle parked, not wanting to risk a road test)
-bad ground(s)?! (I used that lil factory ground point next to radiator near battery)
What do u guys think?
-defective probe(s)
