puty72
1989 ford ranger 2.9 a4ld trans 118,900 miles
below is a list of parts and sensors replace and date
fuel pump, filter, regulator (this week)
reman injectors (aug 2011)
plugs, wires, dist cap n rotor (aug 2001)
coil and air temp sensor ( feb 2011)
coolant temp sensor (july 2010)
module on back of distributor july 2009
throttle position sensor (feb 2010)
map sensor (2011)
air filter (aug 2011)
new magnaflow cats and full exhaust (nov 2010)
and also other things that may or may not pertain to my problem
complete rebuild a4ld trans aug 2012
new Alabama cylinder heads aug 2011
headers aug 2011
new pushrods, lifters, camcraft cam aug 2011
now that i have all parts replaced listed i will tell you whats wrong with my truck.
my truck will idle fine and sound fine when you rev it. while cruising at a normal pace it will shift and run smoothly. sometimes it will act up sometimes it wont if you accelerate hard or go up a hill it will start surging and sputtering. if you let your foot on the gas it will get threw the surging and pull real hard the start sputtering again and if you try flooring it from a dead stop it will get a deep low growl from the intake and move like a slug.
also i picked up a ford code reader and got codes 41 oxygen sensor voltage signal always lean -does not switch and code 63 throttle position sensor- signal voltage too low
i try checking everything from plugs, wires, and even replaced a few parts recently that i replace before within the past two years and still nothing.
any help would be greatly appreciated
map sensor (2011)
headers aug 2011
