Superoir radiator
trick milton
Hey friends! I'm looking to buy a new radiator today. The one I like is from Superior Radiator in MI. MADE IN USA!!! The radiator is a 2 core alu. w/1" tubes. They say it is for Ranger/Bronco 2 with V8. I did a search on TRS to see if anyone had used this and how it fit. If so, can you direct me to the info or if you have any thoughts on this please let me know. PS. I found this on ebay for $300 w/$45 shipping
I don't think rangers ever babe with v8s but I'm not sure on that. Quick search online should tell you. Plus maybe even an install. Most manufacturers have the install instructions on their websites check it out.
There are alot of people who swap a V8 in rangers & broncos. There are also many companies that make products for this swap, this is one.
seems expensive but i don't know much about radiators, and go Michigan made!
Looks like it is intended to be tucked under the core support (common on many V8 swaps)
I do like that it is all metal and has the filler neck relocated so you can still get at it after it is installed. You may have to do some trimming to the core support to install it.
$300 isn't bad at all, when I was on the market a year ago most swap radiators were closer to $500. It even has the tranny cooler installed for automatic transmissions which is another plus.
I finally ended up ordering and buying my radiator. seems to be very nice quality. it did take a little trimming of the radiator support to get it to fit. but it did fit like a the glove and with the extra room from puting it inside the radiator support made it ideal for a v8. there's a picture of it in my album. if I figure out how to post pictures in a post I will post it here.
[/URL][/IMG]
