stupid beeping
Hayden1234
Wisconsin
So ive been having a small problem with my 94 ranger. ill get in start it up put my seat belt on and the stupid beeping that my door is open or my light or seat belt arnt on dosint shut off. it just keeps beeping. also my over head light stays on. ive tried closing both my doors over and over, and puting both seats belts on, nothing works. it shuts off after about 2 min. but id still like to fix it
You have electrical issues. My 88 F-150 had this problem, I don't know what was really causing it, so I just removed the appropriate fuses.
Probably a door position switch.
It is a button in your doorjamb that the door hits when it is closed. Start with the DS door since it probably gets used more and unplug the door switch, should kill the light/buzzer because it will think the door is always closed.
The switches are pretty cheap, one for my '85 was around five bucks.
What year is your truck? On my 98, the door switch was under the latch at the back of the door. The pin in the switch would get gummed up with all kinds of crud and wouldn't pop back up when the door was closed. It was pretty easy to get to once you removed the door panel. To remove the switch, you just twist it 1/4 turn clockwise and pull it down. I used a q-tip and some alcohol to clean around the pin until it would pop back up easily.
Yeah, sounds like the door switch...my 96 beeps because the door handle sticks in the open position and I have to open the door, slap the handle down and then close the door before the thing shuts up...some day I might take it apart and oil that handle...but I'm selling the doors and don't really care too much...
Its a 94, and i didnt think of the senser, ill look at it and clean it and if i need to get a new one, ill do it, thanks everyone
5 beeps 3 times in row? its the airbag beeper, when the airbag light goes out, it has a backup which beeps to let you know of any issues with the airbags, least thats what i found in my explorer. it happens when i first start up and every 15 mins or so.
Yeah, but the airbag MIL won't keep the dome light on.
