5150 does not = 5100
5150s have been known for some issues with the eyes breaking. 5125s and 5100s less so. Though if your bracket isn't wide enough for the eye to not bind up within it, ANY shock is gonna break.
Only thing where I agree is that if you dent them, they are ruined (they are monotube shocks). Because you typically mount a Bilstein body-up, denting them from a rock or something does not seem too likely.
As for the 9000s, that very thing was a huge issue I went through with them (and I actually had the ignoramus at the 4WD place get pissed off at me when I kept bringing them back because they sucked
). Someone at Rancho was apparently too stupid to realize you cannot switch a shock around that has a stud on one end... I eventually cut the eye & the stud off and re-welded them onto the correct ends of the shock so the body would then face down (yeah no more warranty now lol
). This improved them tremendously, but still did not get rid of the rattling effect of the sloppy valving on them (and the comp damping was still pretty weak, though at least there was some finally).
you know what I meant by 5100 series, fugger
all research I did before posting says the 5150 is the exact same build construction as the 5100 and 5125 with an external res... take it up with them
As for binding in the brackets, absolutely agree that that would cause breakage. However... I have run my skyjacker nitro's in the front for years and havent broken a single one..... axle wrap happens beings I am leaf on the front, but I'm going with the bilstein's having weak shafts, due to one being snapped off, and the other being almost snapped off. My shitty skyjacker nitro's are still straight.
Hitting the shaft is just as bad as hitting the body, either way, the bilsteins cannot take damage.
Thats interesting that you had that issue with rancho, were you buying them for a Bronco II? I'm just curious how that ended up being that way.
I'm also wondering about the issues you had, as I searched and searched and through all of the bad I read on the rancho's, I didnt find that issue....
I have not dealt with any other 9000 shock than the 9012, which was the popular rancho... maybe the valving in the RBV rancho was not suitable for your modified suspension... seems plausible to me. There is no way your suspension could make my 9012's do what you are describing. If you cranked them up all the way, your truck would ride stupid stiff, nothing rattling other than your brain and teeth.
Now dont get me wrong, the Bilsteins have a great reputation and are a great shock company, I'm just not sold on the 5100 series of shocks (unless the new ones have bigger shafts and better seals)
I think the best budget shock right now is the BBCS.
Rancho 9000xl's are also AWESOME shocks from what I've seen... completely different than the 9000 and 9000x's. Nitro charged, mount them shaft down, 9 position vs 5, still twin walled.
Downside is price
