- Mar 8, 2008
- Age
- 38
- Homer, alaska
- mostly 86
- Manual
Ream out the pitman arm if necessary so you can use the same TRE?
As long as you set TREs so they rotate the correct way, they will have as much travel or more than a heim does.
i was thinking of using a TRE on the pitman as well. not sure of the other options.
and what do you mean set them so they rotate the correct way? top or bottom of the spindle shouldn't matter, right? my first thought is to go on top.
