rickcdewitt
hey guys thought i'de throw some dumb Q's out there after a little searching and being too lazy to pull the starter and bench check it or borrow a load tester.
i clearanced the brush holders on my starter so the last bit of brush would fall down and contact but now its giving me more trouble in the form of an intermitant click and no start followed by what seems like a big draw that dims the headlights and the rest of the system.
smack the starter a bit and wait and then she starts?
when i had it apart i noticed the bushings/bearings in the starter had enough slop the copper wound part would deflect enough to hit the magets in the case slightly.
do you guys think that would cause a temporary draw that lasts until i turn the key off and on a few times?i guess when it happens again i'll pull the positive lead(to check if the starter is where the draw is) and jumper power to the fuse box to see if the lights are still dim.
when it craps out jumpering power across the solenoid to start it doesn't work
is this rebuild worth it? http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=VLP&MfrPartNumber=FDS03
thanks, rick
thanks, rick
