- Sep 18, 2021
- Staten Island NY
- 4.0 V6
- Automatic
- Total Lift
- N/A
- Total Drop
- N/A
- Tire Size
- 235 75 15
- My credo
- Sometimes you eat the bear, sometimes the bear eats you.
1993 Ranger 4.0 XLT Auto
Prior to having this starter issue dilemma I sprayed a little WD40 on the battery terminals, just after waxing the ranger yesterday, and cleaned the rims. This is very odd. I highly doubt this was the issue.
My starter was replaced last year or maybe even less than a year ago. When I attempt to start it the starter has a clunk/thump sound. I cleaned the battery posts, also the battery load while attempting to start it and it's fine, it doesn't go past 12.2 volts when attempting to start. The voltage is 12.8 volts when not under load, so the battery seems fine.
I'd like to jump the solenoid out but it won't jump out using a screwdriver along both terminals. How do I go about checking the solenoid first before I do anything else as this is my priority currently. Can I use a multimeter, if so how do I check it.
Also if the ground is bad to the starter, is there a way I can ground it without going underneath directly to the starter.
Is there anything I can troubleshoot also to see if the starter is defective. I'll attempt to tap the starter with a hammer while my girlfriend trys to start it later when she gets home from work. It boggles my mind why all of a sudden the starter crapped out.
Thanks
Thanks
